Processors
16334 Discussions
Compatibility Issue with Intel SST Drivers and Windows 11 Version 24H2
Tagadock
Hello everyone,
I recently discovered an issue with my ThinkPad X1 Extreme Gen 5 that may also concern Intel Smart Sound Technology (SST) users.
The microphone volume on my device is extremely low when running Windows 11 version 24H2, making communication on apps like Discord or online games nearly impossible. After extensive troubleshooting and even reinstalling Windows 11 via Lenovo’s USB recovery tool, I identified the root cause: a compatibility problem between Intel SST audio drivers and Windows 11 version 24H2.
In particular:
  • The microphone audio is not being properly amplified.
  • The "Audio Enhancements" option, typically accessible in Windows Settings under System > Sound > Microphone Properties, is missing in version 24H2. This option is present and functional in version 23H2 and earlier, where the microphone works perfectly fine.
This issue seems similar to previous compatibility challenges with Intel SST, such as drivers causing BSODs on Windows 11 24H2.
To temporarily resolve this issue, I reverted to Windows 11 version 23H2, where everything functions as expected. However, this is not a sustainable long-term solution, especially for those relying on up-to-date software.
I am sharing this here to raise awareness and to seek advice from the community and Intel’s team. If anyone else has experienced this issue or found a workaround, please share your insights. Additionally, I would appreciate it if Intel could investigate this compatibility issue and release updated drivers that fully support Windows 11 version 24H2.
Thank you for your attention to this matter!
Earl_Intel
Hi Tagadock,
I appreciate sharing this useful information to us. To better assist you and determine the most appropriate resolution, could you please provide the needed details listed below:
  • Have you already tried contacting Lenovo Support regarding this issue?
Kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have: Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
You can also try following these troubleshooting to try and resolve the issue:
  1. Open Device manager
  2. In System devices > Intel(R) Smart Sound Technology (Intel(R) SST) Audio Controller
  3. Right click and select Update driver
  4. Select Browse my computer for driver software
  5. Select let me pick from a list of available drivers on my computer
  6. Select High Definition Audio controller and install.
Source link: No Audio Output with Intel® Smart Sound Technology Update after...
Earl E.
Tagadock
Hi Earl,
Thank you for your response!
Attached is my log file, generated on Windows 11 version 23H2. Let me know if you’d like me to upgrade to version 24H2 and generate a new log file there for further analysis.
To answer your question:
  • I have contacted Lenovo Support, but they confirmed they only provide hardware support and cannot assist with software or driver-related issues.
  • I also posted about this issue on Lenovo’s community forums, but so far, I haven’t received a satisfactory response.
  • Additionally, I submitted feedback via Microsoft’s Feedback Hub, but I haven’t heard back from them yet.
Similar to what Akhilesh2 described, I cannot see the Intel(R) Smart Sound Technology (Intel(R) SST) Audio Controller driver listed in System Devices, even after attempting the suggested troubleshooting steps.
If there are any other steps you recommend, I’d be happy to try them. Thank you for looking into this!
Akhilesh2
I am also getting same issue and I dont see Intel(R) Smart Sound Technology (Intel(R) SST) Audio Controller driver in system devices. I tried updating Intel® Smart Sound Technology for Digital Microphones. But it didnt work.
Akhilesh2
Device settings for INTELAUDIO\CTLR_DEV_7E28&LINKTYPE_02&DEVTYPE_00&VEN_8086&DEV_AE20&SUBSYS_384617AA&REV_0001\5&1e39661a&0&0000 were not migrated from previous OS installation due to partial or ambiguous device match.
I see above error in driver log though.
Earl_Intel
Hello Tagadock,
Thank you for sharing this useful information with us.
Try this method, download the latest generic Graphics Driver from our website.
Intel® Arc™ & Iris® Xe Graphics - Windows*
Some Graphics Drivers also include audio drivers.
Hi Akhilesh2,
You can also try downloading the latest Graphics Driver on the link above, noted please make sure your Graphics Driver is Intel Arc & Iris Xe Graphics, if not, kindly provide the exact Intel graphics card for us to check.
Earl E.
Tagadock
Thank you for your suggestion. I upgraded to Windows 11 version 24H2 and installed the latest graphics driver as recommended. Unfortunately, the issue persists—the microphone volume remains very low.
For your reference, I have attached the logs generated by Intel SSU on version 24H2.
For the time being, I will revert to version 23H2 to have a functional microphone, as it is critical for my daily use. Please let me know if there are any further steps or updates to resolve this issue.
Thank you for your assistance.
rkaralkin
Hello Tagadock
I have the same problem with audio.
And want o revert to 23H2, but can see that Go Back button is inactive in recovery options and don't know how to do this.
Did you made a fresh Windows installation or there is other way to do this?
Thanks!
Tagadock
Hi @rkaralkin,
I believe that if it's greyed out, reverting to 23h2 is no longer possible, apart from a fresh install.
I did a fresh Windows install from Lenovo's recovery image. It installed version 22h2, which I manually upgraded to 23h2 using the "enablement package" after applying all 22h2 updates : https://www.elevenforum.com/t/kb5027397-enablement-package-for-windows-11-version-23h2-feature-update.19372/
I hope this will help you!
LeonWaksman
Hi @Tagadock
Please check in Windows Update if you can install the latest Cumulative Update Preview for Windows 11 Version 24H2 for x64-based Systems (KB5050094). This update may solve your problem.
Leon
Tagadock
Hi @LeonWaksman
Thanks for your message! I just tested your advice.
Unfortunately, nothing has changed and the issue still remains.
