Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
12439 Discussions
Complain about overheat in Intel i5 8th Gen
ATorr4
I would like to make a complain about the processor Intel i5 8th Gen. So, recently I've bought a new laptop with this processor and it overheats too much (mainly when I play games), it has around 60ºC - 80ºC deppending on what I'm playing. I saw the max temperature of this processor is 100ºC and I don't understand why it can't be higher than 100 cause it's supossed to handle games, so it should be designed for that... To be honest, I feel a bit dissapointed because I was looking for a laptop with lower temperatures and I spent too much money on it (around $1000)
https://www.elcorteingles.es/electronica/A27378077-portatil-asus-vivobook-pro-n705ud-gc214t-i5-8-gb-... This is the laptop I've bought in case anyone needs information in order to reply me (sorry, the site is in Spanish cause I bought it in Spain and I can't find this laptop in an English site, you can use the translator if needed).
Any suggestions? Thank you in advance!
Community Manager
Hello AdrianT95,
Thank you for joining the Intel Communities.
The temperatures 60ºC - 80ºC are still within specifications. It is expected the CPU will reach high temperatures while gaming. Depending on the design of the chassis and/or heatsink then the temperatures the CPU will reach. You may try contacting the ASUS* directly in order to check if they consider or not 60ºC - 80ºC as overheating. This link will give you their contact information https://www.asus.com/es/support https://www.asus.com/es/support
The following link will provide more information about overheating https://www.intel.es/content/www/es/es/support/articles/000005791/processors/intel-core-processors.h... https://www.intel.es/content/www/es/es/support/articles/000005791/processors/intel-core-processors.h...
Fred D.
