Processors
16296 Discussions
Compute Stick STK1AW32SC BIOS availability?
paelgin
I am buying a wiped STK1AW32SC "Compute Stick" and I normally update newly-acquired computers to the latest BIOS and drivers.  I hope to reinstall WIN10 (may be a fool's journey).
Almost nothing in terms of files or any other support is available on the Intel website for this discontinued product and I am curious if there is another repository anywhere.
Phil in gorgeous Young Harris, Georgia, USA
ps, the board for "Compute Stick" was eliminated at some time (within the last two years apparently) for some reason so I am posting this in "Processors"
paelgin
Well, no luck on the BIOS update.  And Windows ran so slow, I changed to Linux Mint.
Now I bought a Compute Stick STK2M3W64CC with 4GB RAM and 64 GB internal storage.  Cannot find the BIOS for this either.   Windows recovery is failing by starting then blacking out, so I thought a BIOS update may be needed.
Phil
AlHill
Bios 0065 is attached.
[W10 is this generation's XP]
paelgin
Thanks for the BIOS files.  I will be working on them later today.
The newer Compute Stick (STK2M364CC, rather than STK2M3W64CC which I listed above) apparently was shutting off due to high temperature.  Using my infrared non-contact thermometer, I found that the temp would climb up to 120F quickly, and when horizontal, will keep getting hotter and then suddenly black out completely (no video, no USB power) shortly thereafter.  When hanging in open air with the fan at the bottom (such that the fan is blowing air up through the fins, which I thought might work since heat rises), the temp rises to about 120F, then comes down to and hovers at about 113-116F.  In the BIOS, I set the fan to run all the time, and ramp up to high speed when needed, but I have not tried to listen to it.
I did restore Windows 10 on that newer one and it runs fine (once I figured out the temperature problem).  When first troubleshooting the mysterious power-downs, I realized it was getting hot.  I gave it mouth-to-fan resucitation and hoped to improve airflow.  I disassembled it and the fins were all clean, so I reassembled it and tried running it some more.  When hanging in free air with the HMDI on the bottom, I can keep it running, but with the case above the fan outlet (where it says Intel) staying between 113F-120F.
Disappointed that Intel got rid of the BIOS files and Forum topics for all Compute Sticks.  I am glad that I can get some support from the community though.
n_scott_pearson
The attached ZIP files provide the final BIOS for the SC and m3CC ICS.
n_scott_pearson
Anything below ~70c (~160f) is perfectly fine and NOT the cause of any failure or shutdown (that would take temperatures in the vicinity of 100c). It is true, however, that the ICS needs to be sticking out into open, flowing air in order to keep itself cool. It cannot be laying flat on any surface.
We all are disappointed that Intel has pulled content related to any of their discontinued products. Unfortunately, they assume that presence of content implies support will be provided and that is definitely not the case (though I think it should be too).
paelgin
Regarding temperature readings, my infrared thermometer is reading the outside case above the discharge for blown air.  The highest temerature reading was about 125f and then the whole thing powers down, including the USB ports.  Once I get it cooled down by blowing extra air through the fan intake, the temp falls and then I can restart the computer.  When restarted, it typically will get hot to about 120f, then cool off to about 112f, all the while running Win10 just fine.
Phil
ps, I updated the BIOS with no discernable difference.
n_scott_pearson
Run the (free) CoreTemp app so you have true, hotspot-level display of the processor core temperatures. Since the Tjmax for the processor is in the vicinity of 100c, it is simple to watch for it going critical. You cannot see temperatures above Tjmax this way (it will just display the Tjmax temperature), but you know that the Tcrit (power off) temperature is only a few degrees C above this.
I have never had any of my ICS do a Tcrit power off, so cannot say for sure, but most BIOS, upon restart, will tell you whether this had actually occurred. Unfortunately, due to the ICS being outsourced products, their BIOS may not meet the same BIOS requirements as the Desktop Board or NUC products.
