Hi guys,
I completed my computer build a couple of month back and initially everything worked fine. Then a couple of month in my computer started to randomly freeze at the same time as the fans went to max revs and the computer hangs. I have an i9 10th gen 10900K processor and the freeze behaviour started after I installed new drivers to my processor. Nowadays the computer updates lots of programs all the time without notifying the user so I cannot be sure. But have anyone of you come a cross the same error? I seem to remember the intel driver installation software stating this install cannot be reversed.
Any advise is apreciated
Segelmange
Hello Segelmange
Thank you for posting on the Intel️® communities. Please share with us the following information:
- Which other updates did you complete on your system?
- Did you recently install any new software?
- Intel® System Support Utility (Intel® SSU) results
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Click on the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click on "Next", then "Save".
David G
David G.
David G.
Hi David,
Thank you for monitoring my reqest for assistance, and sorry for not updating the request.
The issue with the fans and freeze has been resolved. Unfortunately I cannot recall what sorted the issue, but is is solved.
Please close this request.
Again, thank you for your assistance.
Magnus
