Community
cancel
Showing results for
Search instead for
Did you mean:
JChar11
Computer occasionally freezes completely due to IOC Agent.
I have been occasionally running into blue screens and complete freezing of my laptop. When I manually power off and restart the computer I check the Event Viewer in Windows and find the following error before the freezing:
Error:
[7] ERROR ProviderManager.SecurepayBcaProvisioner - Exception during BCA-SGX provisioning
System.Runtime.InteropServices.SEHException (0x80004005): External component has thrown an exception.
at Intel.Pabe.Factor.SgxProvider.AbortProvision(SgxProvider* , UInt32 )
at BCAXInterface.SgxProvider.Provision(String provisionUrl, String providerUrl)
at ProviderManager.SecurepayBcaProvisioner.<>c__DisplayClass16_0.b__0()
Machine Specs:
Laptop Manufacturer: Alienware (17 R4)
Operating System: Windows 10 (1709)
CPU: Intel i7-7700HQ (2.8Ghz)
The source of the error is the IOCAgent. I checked and I have the Intel Management Engine Components installed for version 11.7.0.1054. I have tried a reinstall of the software and no luck so far.
Community Manager
Hello jeanthefrog,
Thank you for joining the Intel Community Support.
Even though your computer contains Intel chipsets with the Intel® Management Engine Interface, you should contact your system manufacturer to address any problems or errors properly.
If the issues started happening a few days ago, you may also restore your computer back to a restore point.
Wanner G.
