Processors
14530 Discussions
Conflicting information regarding Virtualization, VT-x being enabled
MClif
My Environment:
PC = HP 8000 Elite
processor = Core(TM)2 Duo CPU E8400 @ 3.00GHz
Memory = 8 GB
OS = Windows 10 Pro
The big picture:
I am in the process of installing Intel's System Studio IoT Edition on Windows:
https://software.intel.com/en-us/node/705839
and that wants Docker installed.
Installing Docker:
Downloaded and Installed the "Stable Channel" of "Docker for Windows" from this page:
https://docs.docker.com/docker-for-windows/install/# download-docker-for-windows
Docker starts and after a while displays this error message:
"Hardware assisted virtualization and data execution protection must be enabled in the BIOS"
The message directed me to the following to verify Hyper-V and Virtualization where enabled, etc:
https://docs.docker.com/docker-for-windows/troubleshoot/# virtualization-must-be-enabled
Intel Processor Identification Utility says
Intel(R) Virtualization Technology: Yes
Intel(R) VT-x with Extended Page Tables: No
See the attachment: ProcessorIdentificationUtility.PNG
Hmmm VT-x = NO, sounds bad
Maybe Docker is looking at the "NO" and then issuing the error message.
I then tried to create a virtual machine via Hyper-V and that also failed
I started here:
https://docs.microsoft.com/en-us/virtualization/hyper-v-on-windows/quick-start/quick-create-virtual-machine
I executed this command (warning, a long command that is entered on ONE line):
New-VM -Name $VMName -MemoryStartupBytes 2147483648 -Generation 2
-NewVHDPath "D:\Virtual Machines\$VMName\$VMName.vhdx" -NewVHDSizeBytes 53687091200
-Path "D:\Virtual Machines\$VMName" -SwitchName $Switch
And this was the result:
New-VM : Failed to create a new virtual machine.
At line:1 char:1
+ New-VM -Name $VMName -MemoryStartupBytes 2147483648 -Generation 2 -Ne ...
Therefore Docker and Hyper-V are both failing.
Now for some info that seems to contradict the above:
# 1: From the Intel page about the E8400:
Intel® Virtualization Technology for Directed I/O (VT-d) = Yes
Intel® Virtualization Technology (VT-x) = Yes
Note: this seems to contradict what the Processor Identification Utility found.
# 2: BIOS shows the following are enabled:
Data Execution Prevention
Virtualization Technology VTX
Virtualization Technology Directed I/O
# 3: Task Manager, Performance tab:
Virtualization enabled
# 4: Data Execution Protection
I followed the steps on this page:
https://support.microsoft.com/en-us/help/912923/how-to-determine-that-hardware-dep-is-available-and-configured-on-your-computer
wmic OS Get DataExecutionPrevention_Available
TRUE
wmic OS Get DataExecutionPrevention_SupportPolicy
2
"Only Windows system components and services have DEP applied"
0: DEP is enabled for all processes
Policy Level = Always On
wmic OS Get DataExecutionPrevention_Drivers
TRUE
# 5: Hyper-V
looking at Control Panel, Programs and Features,
(left side) click on "Turn Windows features on or off"
Hyper-V, Hyper-V Management Tools and Platform are ON
Given:
Assumption:
Docker is looking at that "NO" and then issuing the error message.
Question: Any idea why "Intel Processor Identification Utility" indicates NO for VT-x and the # 'd items that I listed above seem to indicate otherwise?
Bill
Hi, Bill., Thank you very much for joining the Intel® Processors communities.
In order to provide the most accurate response, I will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Any further questions, please let me know.
Alberto
Hi, Bill., I just received some updates from the research we are doing on this matter, and based on that information we can confirm that the processor does support VT-x and VT-d:
http://download.intel.com/design/processor/datashts/318732.pdf http://download.intel.com/design/processor/datashts/318732.pdf
Discrepancy between CPUID/Hyper-V and documentation can occur if the platform itself does not fully support VT-x. E.g. BIOS must support this feature as well. So, we can confirm the processor fully supports those features for virtualization and in this case we also recommend to get in contact with HP directly to check the BIOS to make sure the platform supports this feature:
https://support.hp.com/us-en/contact-hp https://support.hp.com/us-en/contact-hp
Alberto
MClif
Hi Alberto,
Thanks for the research.
I will contact HP about this BIOS info:
And see if they think it is telling the truth.
Stay tuned
Bill
Hi, Bill., You are welcome. Perfect, yes, the best thing to do is to get in contact with HP directly to confirm that information. Once you get the chance please let us know the response provided by them.
Alberto
MClif
I have had no response to the following that I submitted on 4/25/2017, to HP. It is basically the same as this:
https://h30434.www3.hp.com/t5/Desktop-Boot-and-Lockup/Conflicting-information-regarding-Virtualization-VT-x-and/td-p/6094376 Conflicting information regarding Virtualization, VT-x and I... - HP Support Forum - 6094376
Today, I double checked the numbered items above and see the same results.
Looking at C:\Users\tilt\AppData\Local\Docker\log.txt I see at he end:
< beginning of the log snip-it >
[16:07:59.292][VpnKit ][Info ] vpnkit.exe: connecting to 838ee403-f3dd-496f-a10a-e844733276da:30D48B34-7D27-4B0B-AAAF-BBBED334DD59
[16:08:11.136][Linux ][Error ] Failed to start: Unable to start: The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: 'MobyLinuxVM' failed to start.
Virtual machine 'MobyLinuxVM' could not be started because the hypervisor is not running.
'MobyLinuxVM' failed to start. (Virtual machine ID 838EE403-F3DD-496F-A10A-E844733276DA)
Virtual machine 'MobyLinuxVM' could not be started because the hypervisor is not running (Virtual machine ID 838EE403-F3DD-496F-A10A-E844733276DA).
It then goes on to say:
1) Verify that the processor of the physical computer has a supported version of hardware-assisted virtualization.
2) Verify that hardware-assisted virtualization and hardware-assisted data execution protection are enabled in the BIOS of the physical computer. (If you edit the BIOS to enable either setting, you must turn off the power to the physical computer and then turn it back on. Resetting the physical computer is not sufficient.)
< end of the log snip-it >
I think that the numbered items in my original posting indicate that everything is enabled.
Back to my original question ...
Question: Any idea why "Intel Processor Identification Utility" indicates NO for VT-x and the # 'd items that I listed above seem to indicate otherwise.
Bill
Bill.: Thank you very much for providing that information.
In this case, the best option will be to get in contact with HP directly via phone:
1-800-474-6836
I will do further research to try to gather the information you are requesting. As soon as I get any details on I will post them on this thread.
Alberto R
Bill.: I just wanted to let you know that I just received some details from the research we were doing and the thing is that, since the processor was released back is 2008 there are not much information available currently.
We can confirm the processor supports VT-x, but in regard to the reason why the tool reports that the processor does not support it, is because the tool could be failing reading the information from the processor, a misreading.
Alberto R
MClif
Hi Alberto and all who have helped,
Given the end of Edison I am not going to spend any more time on this topic.
Bill
Bill.: No problem, thank you very much for letting us know that information.
Alberto R
