Processors
16438 Discussions
Confused Memory Supported i7 8700
Wandaws
It is possible i run 64 GB DDR4 3200Mhz with intel core i7 8700 non K feat Z370 Motherboard?
pressed_for_time
Valued Contributor II
Yes. With one condition. The Core i7 8700 CPU supports DDR4 memory up to 2666 speed. Running 64 GB DDR4 at 3200Mhz relies on a Z370 motherboard with XMP support to allow memory to be overclocked to 3200. Most Z370s should do this, to be sure check the board manufacturers specifications and/or Memory QVL list.
I checked a Z370 from one company and it lists memory support as "4 x DIMM, Max. 64GB, DDR4". It's not clear whether this is 4x16GB or  2x32GB.  The Memory QVL list should help on this.
