Processors
13560 Discussions
Continuous USB Overcurrent signal on Laptop
Abhishek1902
Model Number: PH315-52-76WX
Part Number: NH.Q53SI.018
Out of the three USB-A type ports, one of the USB3.0 ports on my "Acer Predator Helios 300" laptop abruptly went defunct even though nothing was connected to this USB port. The system now is continuously showing an OVERCURRENT status on this port. When the laptop is turned ON, it perfectly gets 5v supply on this defunct port, the only problem is no USB device gets recognized by the system.
I checked:
1.) The ESD diodes and choke filter is fine on this USB board and there is no shorting within the data lines or with the power rails.
2.) The USB data lines show good connection with the PCH (cross-checked impedance to the ground with a working good USB port on the same laptop)
3.) Per the schematic, I also checked all resistor pull-ups and capacitors on the "overcurrent signal pins" on the HM370 PCH and they were perfectly fine with proper 3.3v on those PCH OVERCURRENT SIGNAL pins.
4.) Also, there was no updation of drivers noting so when this happened, and all other USB ports are otherwise working fine with full bandwidth.
Still not able to understand what is triggering overcurrent on this port? Any suggestion please
DeividA_Intel
Hello Abhishek1902,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Acer laptop.
In this case, since you have USB issues with a laptop I recommend you to check this issue with Acer since they have built this laptop and they must make sure that all the components and drivers are compatible and supported by the BIOS and drivers.
Bear in mind that Acer uses our generic drivers and customized them for their Acer Predator Helios 300, that is why I recommend you o review this behavior with Acer (laptop manufacturer).
Deivid A.
