Core I7 920 is limited to DDR3-1066?
or i can use 1600mhz with full performance?
is limited to 1066 unless you overclock
Correct, the memory controller on the processor only supports 800 - 1066 MHz memory. You can get 1333MHz memory at 1.5v that will work great with your processor.
PV
