Processors
13546 Discussions
Core i5 11400 siempre con frecuencias entre 4.2 ghz y 4.4 ghz no baja
AlexMadrigal
Hola es normal que la frecuencia del procesador no baje? la bios esta en todo por default
Tengo un buen disipadorTengo un buen disipadorla frecuencia no baja de 4.2 ghzla frecuencia no baja de 4.2 ghz
n_scott_pearson
Super User Retired Employee
Check in BIOS Setup and in Windows to see if the processor is being configured for Maximum Performance. In this mode, I would expect to see this kind of result. Changing the setting to Balanced Response in both places is what you want (though I thought this was the default in Windows 10).
Hope this helps,
AlexMadrigal
Thanks, I did not know about that option on desktop PC, only on laptop. It is useful for games
