Community
cancel
Showing results for
Search instead for
Did you mean:
WKort
Core i5 450M @ 2.40GHz Arrandale
Core i5 450M @ 2.40GHz Arrandale - is it OK if the chip regularly hits 102° C? (temperature tracking via Speccy). Thanks.
AlHill
Well, you may want to use a tool that is a bit more useful and accurate than Speccy.
What operating system are you using?
https://ark.intel.com/products/49022/Intel-Core-i5-450M-Processor-3M-cache-2_40-GHz Intel® Core™ i5-450M Processor (3M cache, 2.40 GHz) Product Specifications
Doc
WKort
Windows 10. I see the max T Junction is 105° C - if the 102° C reading is accurate, is that too close for comfort?
n_scott_pearson
Super User Retired Employee
I would say that it's too close for comfort. Your system is reaching that age where things are going to start to fail. In this case, your processor is overheating and the typical reason for this in units this old is that the Thermal Interface Material (TIM, a.k.a. grease, paste, goop, etc.) that facilitates heat transfer from the processor to the heatsink is degrading (drying up, separating, etc.). If you are handy, you can attempt to replace this yourself, but I have to ask whether it is worth it for a Laptop that is almost eight years old.
WKort
Thank you for the information - very helpful.
