Community
cancel
Showing results for
Search instead for
Did you mean:
JWebb1
Core i5-4590 low GHz
I have recently purchased an i5 4590 quad core 3.3/3.7 Turbo GHz chip however it only runs at 2.57 GHz at max and 78% utilization max. I have tested with a CPU stress test, including Intel's own, so I know this for a fact to be true. my max temps on the CPU are 42 degrees celcius, never went higher. I know my PSU is up to par and my bios (Asus H81M-K) was updated just today to try and fix this issue to no evail. I have noticed my CPU also runs around 0.92 volts at any given time if this helps. Thank you!
Community Manager
Hello JacobW.,
Thank you for joining the Processors Community. I am sorry to hear you are having issues with this matter.
The firs thing I would like to share with you is that we have seen cases where certain settings in the BIOS could limit the processors to reach the spec, this is why I recommend contacting ASUS in order to confirm if any of their BIOS settings could limit the frequency of the processor.
Could you please let us know the following information?
To attach a file, the "attach" option will appear in the bottom right corner of the response box.
Amy C.
Community Manager
JacobW.,
If you need further assistance let us know.
Amy C.
