Hi, actually i have installed Win 7 ultimate Sp1 at 32 bit.
I would install Win7 64 bit but i'm not sure about the compatibilty of processor.
thanks for reply
https://ark.intel.com/products/50179/Intel-Core-i5-460M-Processor-3M-Cache-2_53-GHz Intel® Core™ i5-460M Processor (3M Cache, 2.53 GHz) Product Specifications
Yes, you can run Windows 7 64-bit.
Doc
Buenas tardes. Mi pc ejecuta un Intel Core i5 460M de 2,53 GHz. Estoy actualizando mi sistema windows 7 a windows 10, y quisiera saber si el procesador es compatible con Windows 10. Gracias. Saludos de Argentina
The processor should work just fine with Windows 10 64-bit, but Intel does not support Windows 10 graphics drivers for processors this old. You will be limited to the Microsoft Compatibility driver, which has known issues and only legacy support for graphics APIs (OpenGL, Direct3D, etc.). If you aren't gaming and running heavy-duty graphics applications, this may be no limitation at all.
Hope this helps,
