Processors
14674 Discussions
Core i5-7200u doesn't have VT-x support?
TOrfa
I own a dell inspiron 5566-d64p with core processor i5 7200U and would like to know if it is compatible with VT-x technology
AlHill
It does have VT: http://ark.intel.com/products/95443/Intel-Core-i5-7200U-Processor-3M-Cache-up-to-3_10-GHz Intel® Core™ i5-7200U Processor (3M Cache, up to 3.10 GHz) Product Specifications
Check the BIOS of your machine and see if it is turned on.
Doc
TOrfa
Yes, the option is enabled. But it still does not work.
AlHill
Is the BIOS updated?
What Operating System?
If so, then it is either a DELL bios problem, or the Intel ARK information is incorrect, or the Intel Processor ID utility is incorrect.
Doc
Hello torfao,
The Intel® Core™ i5-7200U Processor supports the Intel® VT-x, you can see the datasheet:
https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/7th-gen-core-family-desktop-s-processor-lines-datasheet-vol-1.pdf https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/7th-gen-core-family-desktop-s-processor-lines-datasheet-vol-1.pdf
Page 48
This is a feature that can be enabled or disabled in the BIOS but it also depends on your computer manufacturer if they decided to have the feature available for your system or not.
You can try updating your BIOS and if you already have the latest version you can try contacting your computer manufacturer to ask if this feature is available or disabled for your system.
Ivan U.
CHuan84
I got same question. And I found solution finally.
In my Acer notebook, I change my BIOS setting from Legacy to UEFI(Need to reinstall whole system), and Vt-x is working now!
