I have several Broadwell (E5-2696V4/SR2J0) CPUs and need to determine the COO. Unlike other Intel CPUs, the COO is not stamped on it. Is there a way to determine the COO from the information that is stamped on the CPU? Thank you.
Hello Keithl,
Thank you for contacting Intel Customer Support.
I understand that you need assistance finding the country of origin of your Intel® Xeon® Processors E5-2696 v4.
I will be more than glad to help you today.
There are 3 different options on how to determine the Country of Origin (COO) of an Intel(R) Xeon(R) processor.
Option 1
With older processors, the COO is marked on the top of the processor itself. For example:
Option 2
Look for the Made in information on the label of the product's box. For example:
Option 3
Request the COO by emailing the following information to COO-Customs-Request@intel.com
- Detailed request
- Intel Product Identifying Information (provide as much detail as possible):
- Processor name and number
- MM#
- Ordering Code
- Batch number (also referred to as FPO; required if MM # is not provided)
- Country where Requestor is located
- Country where Product was or will be imported if different than above
- Approximate date of purchase
For more detailed information, please visit:
In case you require more assistance, please contact us back.
Sergio S.
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
Hi Sergio.
Thank you for your reply. I received these CPUs used so all I have is the CPU itself, no packaging. And I have received several hundred in this condition. I've attached a picture of one. Is there a way to determine COO from the markings on the CPU? Thank you.
Hello Keithl,
You can email COO-Customs-Request@intel.com so they can assist you. Please bear in mind, they might request the following information from you:
Detailed request
MM#
Ordering Code
Sergio S.
Intel Technical Support Technician
