My computer will shut down after a little while and show "Cpu overtemperature Error" the next time you turn on. What is the problem, I have a Q8200 core 2 Quad bought 2 years ago, is it still under warranty?
- Tags:
- CPU
If you receive the error message after restarting the system, it may refer to overheating on the CPU. Make sure, in BIOS, it is not reaching or surpassing 71.4°C. If it is, I'd recommend following the troubleshooting found here:
http://www.intel.com/support/processors/sb/CS-029427.htm http://www.intel.com/support/processors/sb/CS-029427.htm
