Processors
13582 Discussions
Current/EDP Limit Throttling flashes in idle time Yes Intel Extreme Tuning Utility i7-9750h
teumik
Hello. I noticed this situation, the laptop is charging, I go to Intel XTU, and there the (Yes) indicator Current / EDP Limit Throttling flashes in idle time. Why is this happening? Thanks!
voltage 1,250-1,350
max 70w
average 55-60w
teumik
Max44
If you're running Windows 10 Pro, it's possible to disable Power Throttling using the Group Policy Editor.
  1. Use the Windows key + R keyboard shortcut to open the Run command.
  2. Type gpedit. ...
  3. Browse the following path: ...
  4. Double-click the Turn off Power Throttling policy.
  5. Select the Enabled option.
  6. Click Apply.
  7. Click OK.
AlHill
@teumik​ XTU is only for X and K processors. You have an H processor and the readings may be unreliable. Do not use XTU.
Doc
