Processors
14516 Discussions
DAB Radio cuts out due to i7 10700, should I expect this?
AndyMax23
Hi all, my DAB radio cuts out when I turn on my PC. It's very frustrating and none of my other 3 pcs to this. I image that this is due to excessive EMI.
I have isolated the problem to the Processor.
Would be very grateful it you think there is something is amiss here?
Andrew
Bristol, England
Board: MSI Z490i Unify
BIOS: 7C77v13 (can't u/g to the v16, doesn't work)
VGA: Sapphire RX570
PSU: Corsair 450SF (+12v Rail 37.5a)
CPU: Intel i7 10700 (non-k)
MEM: Team Group Vulcan Z T-Force 32GB (2x16GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit
HDD/SSD: ADATA SX8200 Pro 2TB
COOLER: Alpenfone Blackridge w. Noctua NF-A9x14 PWM
Keyboard: Bakker Elkhuizen 840 Design
Mouse: MSIntellimouse (PS2 w. USB convertor) / Apple Mighty Mouse (USB)
OC: None
OS: Windows 10 64bit Professional
n_scott_pearson
Rubbish, you don't get EMI out of the processor. It is something else in the system.
AndyMax23
Well that certainly seems to be the case for the older processors I have sure. Any thoughts on what it may be? There are only two other options that I can see. Motherboard, or NVME drive, as they were the only things plugged in when i ran my tests.
AndyMax23
Update: Removing all components from the Motherboard and turning it on the problem doesn't exist. The moment I put the processor in the problem shows up.
