- I would like to use Crucial DDR3 ram - can anyone tell me what type. I am new at this?? I guess I will run a 64 OS - Also, ant assistance on a power supply and especially video graphics card (~$100 - $150). This is a project I am doing with my son.
Please check on the Crucial Website:
http://www.crucial.com/store/listparts.aspx?model=DP67BG&Cat=RAM http://www.crucial.com/store/listparts.aspx?model=DP67BG&Cat=RAM
Make sure to check the system memory requirements from the link below:
http://www.intel.com/support/motherboards/desktop/dp67bg/sb/CS-031957.htm http://www.intel.com/support/motherboards/desktop/dp67bg/sb/CS-031957.htm
kind regards,
Aryan.
Aryan,
Thank you for your responce. You are the ionly one to help me. I appreciate it!
Questions:
I am trying to identify a video card, and power supply for my sons unit.
I found one: BeForce GTX 460 OC 1 GB gddr5 - Price $180
Can you assist me in a card with similar performance for ~$100 for the Intel DP67BG motherboard (to start out with)
My current configuration is:
Case: Antec DF-85 (ATX case)
Motherboard: Intel DP67BG - P67 Chipset
Processor: Intel i5-2500K
Graphics card: ????
Hard Disk Drive: Segate 7200 (2) TB
Memory: Crucial Ballistix 4 GB (2GB X 2) DDR3 - BL2KIT25664BN1608
Power Supply - I am not sure what size.
Optical Drive - I guess I will take it from his desktop (purchased two years ago)
Monitor - I will use his monitor
I am sorry to bother you with this and I know I am asking alot.:
I guess I am asking if you could assist me in
1. A graphics card
2. A, power supply - not sure about watts and type in an ATX case
3. If you feel that this is a good configuration. If not, could you direct or tweek/modify the components? (i.e. - not enough memory, etc.)
Best Regards.
Chris
Hello Chris,
It is a bit difficult for me to recommend any parts for your system.
I can only provide some links to you but you will need to investigate further.
Power Supply calculator:
http://extreme.outervision.com/psucalculatorlite.jsp http://extreme.outervision.com/psucalculatorlite.jsp
http://educations.newegg.com/tool/psucalc/index.html http://educations.newegg.com/tool/psucalc/index.html
GFX card:
Make sure to check the pci express slot available on the board.
http://ark.intel.com/Product.aspx?id=50244 http://ark.intel.com/Product.aspx?id=50244
Check online for some gfx cards comparison:
http://www.techarp.com/showarticle.aspx?artno=88&pgno=4 http://www.techarp.com/showarticle.aspx?artno=88&pgno=4
Note: Be aware that the CPU has integrated graphics.
http://ark.intel.com/Product.aspx?id=52210&code=Intel%C2%AE+Core%E2%84%A2+i5-2500K+Processor+%286M+Cache%2c+3.30+GHz%29 http://ark.intel.com/Product.aspx?id=52210&code=Intel%C2%AE+Core%E2%84%A2+i5-2500K+Processor+%286M+Cache%2c+3.30+GHz%29
All the best,
kind regards,
Aryan.
