Processors
14579 Discussions
DSA won't install
DaddyBearZ
I've downloaded the latest version of the Intel-Driver-and-Support-Assistant-Installer. I've tried to run it normally, and as an administrator. The screen below is all I get. And there it sits...doing nothing. No error, no nothing. Task Manager shows 0% activity. What am I missing?
I have a Core i7-9700F processor and ASRock z390 motherboard. Is this program not for me?
JayB_Intel
Hi DaddyBearZ,
Thank you for your response. We would like to suggest considering the following steps to help us with the situation. Please see below for your reference:
  1. Check Apps & features inside Windows if Intel® Driver & Support Assistant can be found. If yes, uninstall the app following the article: https://www.intel.com/content/www/us/en/support/articles/000089221/software/software-applications.html . If not, proceed to Step 2.
  2. Check if Intel DSA folder exists in your system. You can go to C:/ProgramData/Intel/DSA (default location). If the folder is present and there are files inside the folder, uninstall the app following the same article below and reinstall the app. https://www.intel.com/content/www/us/en/support/articles/000089221/software/software-applications.html
  3. Check if there are any pending Windows update.
  4. Please check if you are able to run Intel® Driver & Support Assistant via this link: https://www.intel.com/content/www/us/en/support/intel-driver-support-assistant.html
  5. Reinstall Windows OS and Intel® Driver & Support Assistant
Jay B.
JayB_Intel
Hello DaddyBearZ,
We would like to gather more information regarding your system so that we can conduct further investigation and work on a solution for you. Please see below for your reference:
Jay B.
DaddyBearZ
Here is the file.
Thanks for any suggestions.
JayB_Intel
Hi DaddyBearZ,
Jay B.
DaddyBearZ
Hi JayB_Intel,
Steps 1-4 resolved the issue. Thankfully step 5 wasn't needed.
JayB_Intel
Hi DaddyBearZ,
Thank you for the update. We are glad that we have resolved your concern. Since a solution has been found, we will proceed in closing this inquiry. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Thank you, keep safe and all the best!
Jay B.
