Processors
16105 Discussions
Datasheet info.
ns
Good day to you!
Can you please provide the datasheet of below part number.
Part: JHL8440
AndrewG_Intel
Hello @ns
We understand that you are looking for the Intel® JHL8440 Thunderbolt™ 4 Controller datasheet. Thunderbolt™ is a technology that computer manufacturers customize for their platforms. Intel provides firmware and driver updates directly to OEMs (HP*, Lenovo*, Dell*, and so on) and doesn't support their products.
Please allow us to refer you to the proper channel of supports:
If you need help with Thunderbolt™ on an OEM computer, please contact the OEM for the latest updates and technical support information.
In case you are a developer or system designer/integrator:
  • If you need documentation, complete this application
  • For further questions, you may also contact us at: Thunderboltadmin@intel.com
Note:
Intel does support Thunderbolt on Intel® NUC products, and you can learn more from the links available in this article: Support Options for Thunderbolt™. If you do have an Intel® NUC and further assistance is required, please let us know.
We hope this helps.
Andrew G.
AndrewG_Intel
Hello @ns
Note:
We hope this helps.
Andrew G.
AndrewG_Intel
Hello ns
We hope that the information provided has been helpful. Since the thread has been marked as "Solved" we will proceed to close this inquiry now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
