Community
cancel
Showing results for
Search instead for
Did you mean:
BRunn
Detection tool will not detect my cpu, I can't download drivers either.
I recently updated my build. The purpose was to upgrade from my amd to an intel processor, which in turn required a new motherboard, new ram in this case, and a new cooler, etc. I currently am using a Gigabyte z270x Ultra Gaming motherboard with an Intel Core i7 7700k processor. When I try and download the most recent driver (or any older version) it says that "this computer does not meet the requirements for installation."
When I try and use the intel utility tool to identify my processor, it fails and says there is nothing detected. When I check my device manager, it shows 8 intel core i7 7700k processors (probably each core). It states that the current driver is from 2009, and that it is the latest version. I have tried using zip files to locate updates manually for drivers, but these have also changed. The intel tool that identifies the processor only works, and does show that I have an intel core i7 7700k.
Does anybody know a solution? I would very much like to have control over my processor and get the most out of it.
Tags (2)
AlHill
What operating system are you running?
doc
BRunn
Sorry, windows 10 64-bit
n_scott_pearson
Super User Retired Employee
Where are you downloading these drivers from? [Hint: you should initially be using the versions on your motherboard manufacturers web site]
