17060 Discussions
Device Manager Error: Intel Management Engine Interface
woosh4123
If I am using the wrong Board, Please tell me which Board I should use for this question.
On my computer WIN 10 PC Device Manager, I see a yellow “Caution” flag next to Intel Management Engine Interface #1 device.
  • If I click on the properties section, I see the following statement:
  • “Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)”
  • The device has firmware version: 14.5.12.1111
  • The driver is section shows 21181100.0.1078
  • If I say check for driver update, I am told I am using the most up to date version.
  • If I run the Intel Driver & Support Assistant, I get the message: “Your Intel drivers and software are up to date.”
Question (1): Shall I uninstall this device and hope upon rebooting the yellow “Caution” flag will disappear.
Question (2): Should I disable the device and hope my computer will never ‘miss’ it?
Thanks!
n_scott_pearson
Disabling the device can have consequences for features supported (like DRM), so I do not recommend that. What I do recommend is that you uninstall this device, choosing to delete all related software, and then reboot. I would next download the latest Intel Management Engine driver package for your processor/chipset from the Intel Download Center (we can point you to right package if you identify your processor/chipset) and then install it.
woosh4123
Dear N Scott Pearson,
Thanks for your prompt reply.
Please do not confuse me with someone who knows very much about the inner workings of my computer. I will attempt to provide you what I think may be answers to your professional response.  I hope this info is useful to you - it comes from a software called “Speccy” installed on my computer:
Motherboard
            Manufacturer Micro-Star International Co. Ltd.
            Model  H410M PRO-C (MS-7D01) (U3E1)
            Version            1.0
            Chipset Vendor           Intel
            Chipset Model Comet Lake
            Chipset Revision          05
            Southbridge Vendor    Intel
            Southbridge Model     IDA3DA
            Southbridge Revision  00
BIOS    Brand:  American Megatrends Inc.        Version 1.10           Date 9/29/2020
CPU                           Intel Core i7 10700K
                                    Cores   8
                                    Threads           16
                                    Name  Intel Core i7 10700K
                                    Code Name     Comet Lake
                                    Package           Socket 1200 LGA
                                    Technology      14nm
                                    Specification   Intel Core i7-10700K CPU @ 3.80GHz
                                    Family 6
                                    Extended Family         6
                                    Model  5
                                    Extended Model         A5
                                    Stepping          5
                                    Revision           Q0
                                    Instructions: MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, Intel 64, NX, VMX, AES, AVX, AVX2, FMA3
                                    Virtualization  Supported, Enabled
                                    Hyperthreading           Supported, Enabled
                                    Bus Speed        99.8 MHz
                                    Stock Core Speed        3800 MHz
                                    Stock Bus Speed          100 MHz
                                    Average Temperature 30 °C
 I think you suggested removing this highlighted error flagged device:
And any software associated with it. Do you mean this driver associated with the device?
                      heci.inf_amd64_778912adccf3cb\x64\TeeDriverW10x64.sys
I do not know of any other software that might be associated with this device.
And, yes, please - I would need you to point me to right package for me to download.
Thanks ever so much for your insights and guidance. I must however, log off my computer for the night. (It is about 8:30 pm on Saturday 25 September. Please be assured I will read and comply with any advice you send – but tomorrow is the soonest I can “Log On” to my computer again.
Have a pleasant evening and a fun, safe Sunday!
Bill
n_scott_pearson
That's more than enough information.
A version of the ME driver installation package for 10th gen processors/400 Series chipsets can be found here: https://www.intel.com/content/www/us/en/download/19488. Simply extract the contents of the ZIP file and run the MEISetup.exe.
woosh4123
Did as you suggested and can happily report that after rebooting and checking the Device Manager I now see no yellow triangle warning!
Yay!
Also re-ran the Intel Driver & Support Assistant, and got the message: “Your Intel drivers and software are up to date.”
Yay!!!
Thanks very much for you help: What I feared to be a nightmare with your assistance turned out to be a walk in the park!
Yay!!!!
Bill
