Processors
14536 Discussions
Does CPU E5 2620 compatible with UCS-MR-1X162RU (memory)?
hsheh
i need to install a new mermory UCS-MR-1X162RU and i don't have any idea it is going to work with this processor or not any support?
RAJU2529
New Contributor III
better you can contact with the motherboard manufacturer , because newer ram version requires compatible BIOS version , and newer ram needs correct slot
Carlos_V_Intel1
Hello Hamed, Hope you are doing fine. In order to better assist you, can you confirm the motherboard model and the version of the processor you will use (v1, v2, v3, v4)? Regards, Charlie V. Intel Customer Support Technician Under Contract to Intel Corporation
Carlos_V_Intel1
Hello Hamed, We are wondering if you need further assistance from our side? Regards, Charlie V. Intel Customer Support Technician Under Contract to Intel Corporation
Carlos_V_Intel1
Hello Hamed, As we have not received an answer from you we will proceed and close this thread, if you have further questions do not hesitate to contact us again. Regards, Charlie V. Intel Customer Support Technician Under Contract to Intel Corporation
