Processors
15863 Discussions
Does Intel® Xeon® E Processor or Intel® Xeon® D Processor support RDIMM DDR5 memory?
theidleman
I am currently in the process of selecting a processor for my workstation, and I need to ensure that the chosen processor supports RDIMM DDR5 memory. From my initial research,
Could you please confirm whether these two processors support RDIMM DDR5 memory? If they do not, could you recommend some Intel® processor models that do support RDIMM DDR5 memory?
Thank you very much.
pressed_for_time
Valued Contributor I
The Intel® Xeon® E Processor and Intel® Xeon® D Processor ranges cover a large number of processors dating back years.
A listing of Xeon® E processors can be found here and a similar list of Intel® Xeon® D processors is here .
The other issue is motherboard support, if you have a particular RDIMM DDR5 board in mind then the manufacturer will publish a list of compatible CPUs. This may be an easier way of identifying whether a CPU is suitable or not.
theidleman
So you suggest first check motherboard. I got it. Thank you.
