Hello, which low cost Processor including Graphic could replace the one below ?
(Socket LGA1155, discontinued or not)
In my case
This is for testing a PC not booting anymore.
Thanks in advance, Marc.
The proper way to do this is to check with the motherboard/system manufacturer for processors supported by their bios. Then, you can select the lowest/cheapest from those.
Just because the PC is not booting does not mean it is the processor. It could be a bad motherboard, bad power supply, bad memory, etc. People always want to point to the processor without doing the proper debugging/testing.
Hello marcurling
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, I am glad to see that fellow community members have the knowledge and they jumped in and helped. You may also find the Discontinued Products website helpful to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Product Status > "Discontinued".
Hugo O.
