HP provides drivers for your laptop, if it supports windows 10.
Also, Windows 10 provides all the drivers you need, during install and during Windows update.
I doubt seriously that half of your drivers do not work. You did not describe any specific problem.
You provided no real information about your laptop.
Personally, I would do a clean install of windows 10 and deny access to your laptop by this "person". Of course, you should backup your data prior to the clean install.
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
