the tested E3930 SoC (microcode: sig=0x506c9, pf=0x1, revision=0x2c) has issues accessing the 32-bit non-prefetchable memory resource of Xilinx PCIe Endpoint. Within each block of 80-84 bytes only four starting dwords get read correctly, the next dword is the product of dword address, remaining data is zeroed. While the real memory contents are random non-zero data.
The problem appears only on E3930 (in a form of Qseven module), while the same PCIe endpoint works fine with E3845, E3815, x5-E8000. It's also reproducible with Linux (4.8, 4.14) as well as with EFI Shell, changing the PCI/PCIe configuration doesn't appear to help. No errors reported by endpoint/root port.
EFI Shell dump (zeroed data returned is incorrect):
Memory Address 0000000091200000 256 Bytes
91200000: D7 16 2A 88 05 24 64 21-64 80 01 03 00 4C 00 04 *..*..$d!d....L..*
91200010: 00 00 25 04 00 00 00 00-00 00 00 00 00 00 00 00 *..%.............*
91200020: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
91200030: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
91200040: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
91200050: 00 00 00 00 06 00 20 85-00 00 35 16 09 80 1E 21 *...... ...5....!*
91200060: A7 88 46 20 00 00 31 19-00 00 00 00 00 00 00 00 *..F ..1.........*
91200070: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
91200080: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
91200090: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
912000A0: 00 00 00 00 00 00 00 00-E2 90 90 0A 00 00 21 2B *..............!+*
912000B0: 00 00 25 2C 00 28 AD 01-00 00 25 2E 00 00 00 00 *..%,.(....%.....*
912000C0: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
912000D0: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
912000E0: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
912000F0: 00 00 00 00 00 00 00 00-00 00 00 00 C3 B0 0C 71 *...............q*
91200100: 28 42 84 42 0A 20 00 87-08 81 49 00 20 55 54 81 *(B.B. ....I. UT.*
91200110: 00 00 25 44 00 00 00 00-00 00 00 00 00 00 00 00 *..%D............*
91200120: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
91200130: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
91200140: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
91200150: 00 00 00 00 20 8A 9C 81-00 00 35 56 08 21 C9 57 *.... .....5V.!.W*
91200160: 00 08 88 81 00 00 31 59-00 00 00 00 00 00 00 00 *......1Y........*
91200170: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
91200180: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
91200190: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
912001A0: 00 00 00 00 00 00 00 00-A5 10 00 18 00 00 21 6B *..............!k*
912001B0: 00 00 25 6C 01 04 C4 40-00 00 25 6E 00 00 00 00 *..%l...@..%n....*
912001C0: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
912001D0: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
912001E0: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
912001F0: 00 00 00 00 00 00 00 00-00 00 00 00 2C 40 42 10 *............,@B.*
91200200: 00 12 84 0D 10 26 0C 01-79 C0 00 12 4A E0 8E 12 *.....&..y...J...*
91200210: 00 00 35 04 00 00 00 00-00 00 00 00 00 00 00 00 *..5.............*
91200220: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
91200230: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
91200240: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 *................*
91200250: 00 00 00 00 81 21 *.....!*
Hello lebon
Thank you for joining the community.
Allowed me to share with you that on this community we can provide you assistance on boxed processor, in your case the Intel Atom® x5-E3930 Processor is an embedded product, to assist you on a proper way please refer to the Intel® Embedded Community on the following link
https://embedded.communities.intel.com/select-display-name!input.jspa?reg=1 https://embedded.communities.intel.com/select-display-name!input.jspa?reg=1
Leonardo C.
