Processors
14534 Discussions
E5200 Low CPU Speed
Hey, I've got a INTEL Dual Core 5200, which is 2,50GHZ, I downloaded a program called CPU-Z and according to it, my cpu speed is 1,20ghz, HEEELP
Hi there,
Actually from the link below, the cpu should work at 2.50Ghz.
http://ark.intel.com/Product.aspx?id=37212&code=e5200 http://ark.intel.com/Product.aspx?id=37212&code=e5200
Try this utility to see if it makes any difference
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&ProductID=1881&DwnldID=7838 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&ProductID=1881&DwnldID=7838
If you are using an Intel Board, try this software as well:
http://www.intel.com/design/motherbd/software/idu/ http://www.intel.com/design/motherbd/software/idu/
If it is not Intel board, check with the board manufacturer if there is anything from their side that can fix or possibly a bios which can fix this.
All the best,
Aryan
