Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
E5300 temperature question
Greetings,
i've got my brand new intel E5300 and i have a question. it's set to 2,6 Ghz and its temperature is 40 C normal and 60 C in stress. Is this ok with this type of processor or should i set lower multiplyer ? Thanks for any quick help
Community Manager
It is still operating within the threshold temperature range which 74.1C.
http://processorfinder.intel.com/List.aspx?ParentRadio=All&ProcFam=0&SearchKey=e5300
All the best,
Aryan.
Community Manager
Hello!
Is that normal that its temp. is sometimes over 90C is? And its changing very fast. It rises or drops in 5 secs about 10C.
Shall i get a new cooler, or can be that the sensors are dead?
Thanks: Oryk
DSilv11
Valued Contributor III
ouch, at 90 you are likely into thermal throttling.
It is not likly to be the temp sensor, so I would take a close look at you heatsink solution, fans and air flow.
40 - 60 is great
60 to 75 is ~ OK
> 75 is really hotter than you want.
Community Manager
I have fans 1 in front and 1 in front of the CPU. So i think it must be enough air flow.
There is a fan on the back aswell, maybe ill try to use that in spite of the middle one.
Community Manager
Many thanks, i was looking for this thermal specification for hours your post was a great help
