Yesterday I took my computer back from MSI repair center,They said my laptop hardware was fine,And no crashes or other errors occurred during the high overload test for three consecutive days.
They updated the BIOS and cleaned the cooling module, removed the original 8G-RAM, leaving the self-purchased 16G-RAM, and asked me to test again to see if it would happen.
But unfortunately, this happened again when I played Helldiver 2 yesterday.
One of their suggestions is to replace the self-purchased 16G-RAM, and the other is to disable intel dynamic tuning.
It's not clear to me whether to disable intel dynamic tuning as they say or replace with new RAM or SSD.
I also followed the driver download point released by MSI official website and updated all the drivers,but he still happens.
I have not made any additional modifications to my computer, everything is according to the original factory settings.
Below is a screenshot of my computer system and error report
This is the latest reply from MSI. They want me to restore my computer to factory settings:
ESIF components are part of the Intel Dynamic Platform and Thermal Framework (DPTF), which is commonly used to manage power consumption and thermal dissipation in laptops. It is responsible for coordinating hardware performance and temperature control.
And Unauthorized EsifEventRegister indicates that some module or service was denied authorization when trying to register an event. The problem may involve a problem with the system driver (for example, the Intel DPTF driver is not installed correctly or is damaged).
If this error occurs frequently and affects game operation, we recommend that you try to restore the laptop to the factory system and check if there are any abnormalities in the factory system
The situation seemed to improve after I restored the computer to factory settings and updated Windows 11 to the 24h2 version (originally the 22h2 version)
At least the computer overheating problem no longer occurs when playing Helldiver 2.
I will continue to test whether this method is effective, and the problem [ESIF(1.0.10702.25133) Type: Error Module: IPF] did not appear during this 2-hour game.
If it happens again I will update the post again
Hello AngelCityElite,
I understand that you are encountering issues with your system. I really appreciate your effort on troubleshooting until the issue was fixed. Should you encounter any issues again, please let me know so I could investigate this matter.
Jed G.
I have a new problem now:
SCEP Credential registration initialization for WORKGROUP\MSI$ via https://INTC-KeyId-134d03d6581dabea3bf82eb2e34bf98192826962.microsoftaik.azure.net/templates/Aik/scep failed:
GetCACaps
Method: GET(0ms)
Stage: GetCACaps
Unable to resolve server name or address 0x80072ee7 (WinHttp: 12007 ERROR_WINHTTP_NAME_NOT_RESOLVED)
I'm sorry to hear that you have a new problem now. Please share the information below for me to address this properly.
1. Was the system working fine before?
2. Did you make any recent changes to the system?
Please also generate SSU report for me to check your system configuration.
I look forward to your response
Jed G.
Thank you for answering the questions. For further troubleshooting, please update the graphics driver to the latest version 32.0.101.6458 and make sure to perform clean installation. Please check if this step will improve anything.
Jed G.
I wanted to check if you had the chance to review the recommendation I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
Hi AngelCityElite,
I'm glad to hear that the issue was resolved after following the recommendation which is to update the graphics driver. Please continue monitoring the system and should the same issue persist, please create a new thread as this thread will no longer be monitored.
Jed G.
