17029 Discussions
Error While Applying Values on Intel Extreme Tuning Utility
MadMaximusJB
Running an Intel i5-9600K CPU @ 3.70GHz
Hello, I am running into an error when attempting to use the automatic optimization of power and current limits on the Intel Extreme Tuning Utility. Error reads: "an error occurred while applying values". Images of all errors displayed below. Please advise on what might be causing this. Thank you.
ACarmona_Intel
Hello MadMaximusJB,
May we know if automatic optimisation of power and current limits on the Intel Extreme Tuning Utility worked fine before? This is to check if you might have made changes to the system that might cause the issue.
We look forward to your response.
Carmona A.
MadMaximusJB
The application displayed this behavior on install.
ACarmona_Intel
Hello MadMaximusJB,
Thank you so much for the response.
Highly noted. We will do further research on the issue to provide you with an appropriate recommendation, and I will post the update on this thread once it is available.
Carmona A.
ACarmona_Intel
Hello MadMaximusJB,
Thank you for patiently waiting on our response.
To further assist us in delving deeper into this issue, please provide the following details:
1. Is it possible for you to choose any IccMax value other than 'unlimited'?
2. Does the error occur exclusively with the highest IccMax value, or are there other values that also trigger the error?
3. What is the make and model of the motherboard?
We look forward to your response!
Carmona A.
ACarmona_Intel
Hello MadMaximusJB,
We are checking in with you to see if you already have the answers to our questions so we can further isolate our issue.
Thank you, and have a great day!
Carmona A.
ACarmona_Intel
Hello MadMaximusJB,
We are checking in with you, as we have not heard any response from you.
Carmona A.
ACarmona_Intel
Hello MadMaximusJB,
We have not heard back from you, so we will close this enquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Thank you, and have a great day ahead.
Carmona A.
Intel Customer Support Technician
