Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11685 Discussions
Extreme tuning utility won't start
FMing
After getting a warning that my ssd was near full, i found out intel xtu log files were over 65GB. I uninstalled and installed it again but it won't start, it says "Unable to start Intel Extreme Tuning Utility. If there is another performance tuning application running, you must close it before trying to start this application.".
Below is the log file that is generated every time it fails to open.
2018/01/20-22:00:59.4494|IMP] About to display splash screen
2018/01/20-22:00:59.4823|IMP] Loading Themes
2018/01/20-22:00:59.4833|WARN] Could not find customized skin. Loading default Black Color Theme
2018/01/20-22:00:59.5204|IMP] Application On Startup event called
2018/01/20-22:00:59.5204|IMP] Starting up UI
2018/01/20-22:00:59.5204|IMP] Showing Startup Window
2018/01/20-22:00:59.5965|!ERR] GUI is waiting for service in start pending state to start
2018/01/20-22:01:59.7176|!ERR] Could not find a PerfTuneService instance
Source Init event subscribed
2018/01/20-22:02:03.9737|IMP] About to close splash
2018/01/20-22:02:03.9747|IMP] Saving application settings
2018/01/20-22:02:03.9988|!ERR] Microsoft.Practices.Unity.ResolutionFailedException: Resolution of the dependency failed, type = "ITelemetryManager", name = "". Exception message is: The current build operation (build key Build Key[PerfTune.Managers.ITelemetryManager, null]) failed: The current type, PerfTune.Managers.ITelemetryManager, is an interface and cannot be constructed. Are you missing a type mapping? (Strategy type Microsoft.Practices.ObjectBuilder2.BuildPlanStrategy, index 2) ---> Microsoft.Practices.ObjectBuilder2.BuildFailedException: The current build operation (build key Build Key[PerfTune.Managers.ITelemetryManager, null]) failed: The current type, PerfTune.Managers.ITelemetryManager, is an interface and cannot be constructed. Are you missing a type mapping? (Strategy type Microsoft.Practices.ObjectBuilder2.BuildPlanStrategy, index 2) ---> System.InvalidOperationException: The current type, PerfTune.Managers.ITelemetryManager, is an interface and cannot be constructed. Are you missing a type mapping?
at Microsoft.Practices.ObjectBuilder2.DynamicMethodConstructorStrategy.ThrowForAttemptingToConstructInterface(IBuilderContext context)
at BuildUp_PerfTune.Managers.ITelemetryManager(IBuilderContext )
at Microsoft.Practices.ObjectBuilder2.DynamicMethodBuildPlan.BuildUp(IBuilderContext context)
at Microsoft.Practices.ObjectBuilder2.BuildPlanStrategy.PreBuildUp(IBuilderContext context)
at Microsoft.Practices.ObjectBuilder2.StrategyChain.ExecuteBuildUp(IBuilderContext context)
--- End of inner exception stack trace ---
at Microsoft.Practices.ObjectBuilder2.Builder.BuildUp(IReadWriteLocator locator, ILifetimeContainer lifetime, IPolicyList policies, IStrategyChain strategies, Object buildKey, Object existing)
at Microsoft.Practices.Unity.UnityContainer.DoBuildUp(Type t, Object existing, String name)
at Microsoft.Practices.Unity.UnityContainer.Resolve(Type t, String name)
at Microsoft.Practices.Unity.UnityContainerBase.Resolve[T]()
at IronCity.Common.IoC.Resolve[T]()
at PerfTune.AppManager.OnExit(ExitEventArgs e)Exception trying to cancel software update
2018/01/20-22:02:03.9998|IMP] Splash closed
n_scott_pearson
Super User Retired Employee
Are you sure that, when you uninstalled XTU, it actually deleted the log and configuration files? Uninstall again, delete the folder containing the log and configuration files and then reinstall the application.
Hope this helps,
FMing
Yeah, since the log files were taking all my free space i made sure every file was correctly deleted before reinstalling. After getting this error i fully uninstalled it and reinstalled it again, but to no avail.
n_scott_pearson
Only other thing I can think of is, after uninstalling but before rebooting, (a) make sure installation folder is completely gone and (b) see if you can zap any associated entries being left in the registry.
If this doesn't work, ICS will need to escalate...
