Hi, I'm trying to make a designed system and cut down from a E5-2650 V4 *2 cpu to a cheaper one.
The key dependency lies in the float point capabilities, but I cannot find the data sheet on FLOPS any where, so I asked here(Intel) for help
1. How much the float point unit assigned to each physical core or logic core of E5-2650 V4? Is it different from i7-8700K?
2. Can you provide a detailed table on each CPU on its float point capabilities so that I can make an accurate decision? (ignore the difference of cpu working frequency)
Thank a lot... If you could not help, please let me know
You can find the data sheets here:
https://www.intel.com/content/www/us/en/processors/xeon/xeon-technical-resources.html Intel® Xeon® Processors Technical Resources
Doc
Thank you.
But I cannot find any description on the allocation of AVX unit per physical core / logical core
There might be some chip design document which shall be able to make it clear....
Hello Heermosi,
Thank you for joining the Intel Community Support.
To get further support, you may also go to our Intel® Developer Zone Forums. You can find the link below.
https://software.intel.com/registration/
Wanner G.
