Flickering black screen occurs while the pc is turned on in both the bios and the operating system, in my case, windows 10 x64. The problem is excruciating when I use the processor's integrated graphics system, an intel core i5 10400 on a B460 Aorus pro ac motherboard.
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Doc
There it goes attached. The bios is updated to the latest version
This is resolved. The problem was the display port cable from the graphics card to the monitor, which was in bad condition.
In the bios also? Use better quality cables. And,update your bios.
Doc
