Olá a todos ! preciso de ajuda, o processador
Xeon® E5-2630 v3 trabalha com o ddr4 e tem frequência 1600/1866mhz, No caso estas frequências e para o padrão DDR 3 ? To meio perdido nisso, ou estas memorias e para as ECC ? me ajudem por favor. brigado!
No, these are indeed DDR4 frequencies. The processor has support for ECC memory built into it, but whether you can actually use memory with ECC support is dependent upon the motherboard that you are using.
Hope this helps,
Hope this helps,
Hope this helps,
Hope this helps,
thanks a lot friend for your help. God bless you. you helped me a lot
