Processors
13569 Discussions
G4400 (BX80662G4400) compatible memory speed
User1572502646791536
Hi
Can someone please confirm if DDR4 memory with a speed of 3200Mhz is compatible with the G4400?
AlHill
For your processor, https://ark.intel.com/content/www/us/en/ark/products/88179/intel-pentium-processor-g4400-3m-cache-3-30-ghz.html, only memory of DDR4-1866/2133, DDR3L-1333/1600 @ 1.35V, is supported.
Doc
n_scott_pearson
Super User Retired Employee
Al is absolutely correct. Operation at any speeds above the rated limit(s) is not validated nor guaranteed by Intel. It is possible that faster speeds could work, but many other factors come into play - motherboard circuit and component quality, DIMM quality, etc. Further, while it might work initially, it may not over time. As the processor, motherboard and DIMMs age, they naturally produce more noise and the overall noise can eventually reach levels where the data cannot be distinguished from the noise. Bottom line, I would stick with DIMMs that do not go above the rated speed for your processor.
