Hello!
Please add support for the "GNA Scoring Accelerator" driver for Coffee Lake processors.
Add the ID "VEN_8086&DEV_1911" of the "Intel GMM Scoring Accelerator module" coprocessor in the Intel Coffee Lake processor to the "Intel GNA Scoring Accelerator module" driver.
At the moment, the GMM driver is outdated and it has not been updated by you since 2015, that is, Intel. The GMM coprocessor module is present in the Coffee Lake processor. This processor was released in 2018. The Coffee Lake processor officially supports Windows 11.
The initial GNA driver was released in 2017, but without coprocessor support in the Coffee Lake. The GNA driver is still being updated by you.
I demand to fix this flaw in the GNA driver.
8th-gen-core-family-datasheet-vol-1.pdf
8th-gen-core-family-datasheet-vol-2.pdf
Driver GMM: https://www.catalog.update.microsoft.com/Search.aspx?q=GMM%20Scoring%20Accelerator
Driver GNA: https://www.catalog.update.microsoft.com/Search.aspx?q=intel%20gna%203.0.0.1400
@DeividA_Intel , Why are you using an outdated 2015 driver for your product?
Thanks to Intel for the brazen closure of discussions (05492524, 05493521, 05493772)!!!
That is, you closed the discussions and left them unanswered.
Hello imvagsig,
Thank you for posting on the Intel® communities. I understand that you have a request related to the Coffee Lake processors.
1. Can you provide the specific processor you are referring to or the one you are using?
2. Are you working on a project? Can you provide more details?
3. Are you working for a company?
Deivid A.
Hello!
1. I have a processor in an i7 8750h laptop, but this problem affects all Coffee Lake 8th and 9th generation processors.
2. No
3. No
Read carefully the first post and please understand the problem.
Hello imvagsig,
Thank you for the information provided
I am sorry for the inconvenience. I will proceed to check the issue internally and post back soon with more details.
Deivid A.
Hello imvagsig,
Based on the research, all the information related to the GMM-GNA can be found in the following link:
If you need support and a driver related to the Intel® GMM-NNA I recommend you to get in contact with the manufacturer of the laptop.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
Hello!
The OEM manufacturer has nothing to do with the development of the driver since only you Intel develop this driver and therefore you are responsible for the development of the driver!
Hello imvagsig,
Thanks for confirming the information. I will proceed to check this request internally. However, bear in mind that even if Intel develops a driver, we provide this generic driver so the manufacturers can customize it to fit their systems.
As soon as I have any information I will let you know.
Deivid A.
Hello imvagsig,
Based on the research performed, I would like to let you know that we develop the generic driver and provide it to the manufacturers (HP, Dell, Asus, etc) and they customized this driver so it fits perfectly with their specific device.
I recommend you redirect this question to the laptop manufacturer and if is needed they will work that with us directly.
Deivid A.
Hello, @DeividA_Intel , thanks for your reply!
Why don't you provide here a link to this universal driver with support for ID "VEN_8086&DEV_1911"?
Hello imvagsig,
Thanks for your response. In this case, the driver is provided directly to the manufacturers and is not meant for the end-users. I am not able to provide you with the driver.
As per the question about if the 8th generation product has the support of GNA in hardware, I will review it internally to confirm the information.
Deivid A.
Hello!
Do you already have updates on the issue?
Hello imvagsig,
Thanks for your patience. Based on the investigation performed the processor only supports GMM Scoring Accelerator and the driver is provided exclusively by the motherboard (if desktop) or the laptop manufacturer.
Bear in mind that Intel does not provide the driver. As for the complete GNA technology, it is only supported and validated on platforms with 11th generation processors and newer.
As per the 8th gen CPU only has GMM but not GNA. Therefore, the lack of GNA listing for the i7-8750H is accurate.
Deivid A.
Hello imvagsig,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
Hello imvagsig,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Remember that you can check with the laptop or motherboard manufacturer for the drivers and instructions since they customize their system and can add and block features.
Deivid A.
