hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Processors
16039 Discussions
Genuine Intel(R) CPU U4100 1.3Ghz & Intel Pentium processor SU4100 1.3Ghz
I bought an Acer 4810TZG laptop last weekend, and figured out the CPU displayed in BIOS is different from what it should be:
In BIOS system, it shows Genuine Intel(R) CPU U4100 1.3Ghz
But the hardware vendor says the CPU is Intel Pentium processor SU4100 1.3Ghz, this is what i can see in the box.
So I am not sure what's the difference between these two, is it BIOS display issue or something else.
Meanwhile, i have used Intel processor identification utility to check the CPU type, it shows below:
Would anyone help me to clarify what's the difference between these two CPUs.
Thanks a lot! :-)
Hi, the U4100 doesn't exist, i think iot is just missing the "S" in the name in the BIOS.
I have the same problem. I don't understand the diference.
How can you say U4100 doesn't exist if the Intel Processor Identification Utility show it?!
Do you clearify the issue?
I have a Samsung laptop with an U4100 1.3 Ghz processor and i need to know if i can install Windows 7, 64 bit on it. if you acn help me in this matter, please do.
Thank you.
My laptop (ACER) has U4100 1.3Ghz and it has a pre-installed Win7 64bit. So I think the answer is yes.
