Processors
14532 Discussions
Good fps but bad performance
ICamp
May seem contradictory, but that is what has driven me crazy.
I have a problem about 3 months, and I've done a thousand things to try to solve, and nothing solves it. A little less than 2 years I set up my PC, perfect, everything was running perfectly, after a while, all games were bad, with no flowing mouse, something like playing games in the background, the markers mark a FPS pretty good, but the impression I have when playing, is that it is VERY inferior to that mark. The PC does not give a signal, even a lock, perfect temperature, this is driving me crazy ... I've done everything I could and could not do, first I switched the HD to an SSD, I got no results. I replaced the motherboard and RAM, nothing. I bought a 1060 6GB, and to get me finished, continue with the problem. I formatted several times, I tested play without any program installed on the PC, as it could be conflict, and no results. I swapped mouse, monitor, mousepad and even the line filter. I'm about to give up on this computer, because I already spent what I did not have, believe me. Only pieces that I did not change were: Font and Processor. Have you seen anything like this, can you be my processor? I believe that source does not affect performance.
All my drivers are up to date. I used a b85m-e / br when the problem started, and switched to a b85-g43 from msi (new) and nothing was solved. As for the test without the video card, I did the test in some light games, and all of them got a heavy "sensibility" on the mouse, and if I increase the sensitivity, I totally lose the precision, the aim is uncontrollable when i move. I'm sure it's not the mouse, because I already tested 3 different ones.
Thanksm sorry my bad English.
Specs:
i7 4790
GTX 1060 6GB Zotac (had a 770 windforce)
MOBO MSI B85M-G43
1x8GB RAM DDR3 1600mhz hyperX
SSD 240GB Kingston
1.5TB HD
Hello cAMPIOTI
Thank you for joining the community
In order to get more information on your case could you provide us with the following?
  • The Intel® System Support Utility for Windows* you can download it at the following link
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Please attach the result .txt file to the thread
  • The CPU usage when you have this bad performance problem
  • The FPS that the system is reporting
Leonardo C.
ICamp
Hello Leonardo,
Thanks for answering!
I currently play 2 games, PUBG and CS: GO, and the problem is perceptivel in both games.
Everything seems to be normal, in CS: GO usage stays: GPU ~ 50% and CPU ~ 45% most of the time. With FPS 200 ~ 280 and some drops up to 150 when I shoot (all on low, 1280x960).
In PUBG, where the problem gets quite noticeable, CPU usage is 30 ~ 40% and GPU 80 ~ 90%. The FPS appears to be normal, ranging from 60 to 120 depending on the region of the map (all in low, 1920x1080). But I notice something strange, when I move fast, or when there are a lot of people close to me, the game gets "heavy" and gives a feeling of low FPS, very bad.
Thanks a lot!!
n_scott_pearson
Are you sure this "feeling" isn't the result of network lag?
