Hello FLópe,
Thank you for posting on the Intel Communities.
I was checking your request and I would like to provide you with the following link, where you can check the compatibility of the processors and the operating system (Under Processor OS compatibility):
http://compatibleproducts.intel.com/ProductDetails?activeModule=Processor%20OS%20Compatibility
I checked the 6th generation processors and Linux Kernel is supported on all of them.
Note: You will need to click on the Expand all option to be able to see the list.
Regarding the compatibility of the OS and the motherboard, I would recommend you to get in touch with the motherboard manufacturer to check if this OS will be supported and will work as desired.
Abigail G
Under Contract to Intel Corporation.
六代的1151针脚CPU绝大多数不兼容ubunto系统,因为1151针脚CPU压根就不兼容ubunto系统,这是硬件的软件支持架构学问题,具体原因是因为CPU通路计算电路模式架构不兼容, 建议使用至强E5以上的E7CPU比较好
Hello everybody,
I would like to clarify that the sixth-generation processors are compatible with Linux* Kernel. If you would like to clarify if the motherboard supports Ubuntu* then we will recommend you to check with your motherboard manufacturer.
Abigail G
