Does
Intel only provides v frame specifications. Famvorite employee questions.
You have to find out from the mm manufacturer. However that socket seems identical in the cooler specs. Like it was supposed to be universal.
Waterblock
Hello RR3,
Thank you for posting on the Intel* Community.
These are our recommendations when looking for a compatible cooling solution:
I was checking the specs of the cooler you sent, according to the EVGA website the cooler is compatible with Intel LGA20XX/1200/115X/1366 and upcoming variants, the Intel® Core™ i9-10940X X-series Processor uses the FCLGA2066. We cannot ensure compatibility, since the EVGA* website does not show the TDP of the cooler.
Our best recommendation is to follow the above steps to find a compatible cooling solution, and before buying it, check with the manufacturer to verify the specifications and full compatibility.
Maria R.
Hello RR3,
Maria R.
