Hello TVanL3,
You can find the perfeq bit information on the following URL:
https://www.intel.com/content/www/us/en/processors/xeon/xeon-e5-v4-datasheet-vol-2.html
Page 166.
Sergio S.
My problem is that I want to check the value of this bit on my system but I don't know how to
Thank you
Thomas
Hello TVanL3,
Can you please confirm what is the specific value or information that you need?
Sergio S.
A Contingent Worker at Intel
I have to check if the perfeq bit is set in my system so I need to know how to have access to the value of the perfeq bit
I want to know if its value is 0b or 1b
Thank you
Thomas
Hello TVanL3,
We are going to investigate on your question and will get back to you.
Sergio S.
Any update on my problem ?
Thank you
Thomas
Hello TVanL3,
Can you please let us know more details on why he needs the perfeq bit value?
Do you have details on what you are exactly doing or trying to achieve?
Sergio S.
Hello TVanL3,
We are following your question and we would like to know if you need more help.
Sergio S.
Hello TVanL3,
Sergio S.
Hello TVanL3,
In case you need further help please contact us back.
Sergio S.
Hello TVanL3,
Thank you for the information, we will get back to you as soon as we can.
Sergio S.
Hello TVanL3,
Thank you for contacting Intel Customer Support.
First, we would like to apologize for the delay in our response.
Can you please let us know if you have access to XDP blue box? Like the one listed here:
https://designintools.intel.com/In_Target_Probe_Debug_Tool_Kit_p/itpxdp3brext.htm
Or do you need to read the register thru OS? If so what is the OS you are using for this?
Sergio S.
Hello TVanL3,
We are following your questions and we would like to know if you need more assistance.
Sergio S.
Hello Sergio,
I don't have a XDP blue box so if it is possible to access registers thru OS that would be better :)
I am using a Ubuntu server 16.04
Best regards
Hello TVanL3,
We just received an update on your case:
Broadwell supports four PCIe ports: one is DMI port0 (00:00.0) and port 1.a (00:01.0) x8, port 2.a (00:02.0) x16 and port 3.a (00:03.0) x16.
So, you have to select one port and use the command:
setpci -s 00:02.0 254.l
If you do not know which port to read, you can use number lspci –t –v and identify the attached PCIe card.
Sergio S.
Hello TVanL3,
Sergio S.
Hello TVanL3,
Sergio S.
Hello Sergio,
I managed to check what I wanted thanks to your reply !
Thanks a lot for your help !
Thomas
Hello TVanL3,
We are glad to hear that we were able to assist you, we are going to close this thread.
In case you need more assistance please contact us back.
Sergio S.
