Processors
16417 Discussions
Hello , I own a gl552vw equiped with i7 6700hq , i'm facing a issue atm : i have downloaded intel xtu to undervolt my cpu however i found a bug , my default values where messed and when i attempted to correct them i think i overvolted . My cpu VID is atm
hsaou
Hello , I own a asus gl552vw equiped with an i7 6700hq , i'm facing a issue atm : i have downloaded intel xtu to undervolt my cpu however i found a bug , my default values where messed and when i attempted to correct them i think i overvolted . My cpu VID is atm 1.23-1.28 max is this normal ,
since its a laptop i cant change or verify any voltage from the bios interface , i did uninstall the xtu program , will reinstalling Windows reset the voltage ? kind regards
(Virus scan in progress ...)
Hello Aktosh,
Thank you for contacting the Intel community.
Please bear in mind that this is not an unlock processor and changing the processor frequency or voltage will cause your system to be unstable.
The Intel® XTU reads the information from your computer BIOS, so if you make changes to the voltage from the Intel® XTU reinstalling the operating system will not take effect.
The voltage you show should be ok; you can check this processor voltage range here:
http://www.intel.com/content/www/us/en/processors/core/desktop-6th-gen-core-family-datasheet-vol-1.html http://www.intel.com/content/www/us/en/processors/core/desktop-6th-gen-core-family-datasheet-vol-1.html
See page 112
Ivan.
Hello Aktosh,
See page 112
Ivan.
hsaou
Hello , Thank you so much for the help , i'm relieved at the moment, i'll make sure to document before taking any action
I'have a last question : Can a bios update reset values to factory(volts) ? Thanks again , i wish you a good day
Kind regards
Yes, you can try a BIOS update, you can also try to access the BIOS press F9 on your keyboard to set the BIOS to default settings and then press F10 to save all changes and that also set your processor values to default settings.
Ivan.
