Processors
16486 Discussions
Help! i9 12900k Random BSOD Watchdog_Clock_Timeout
Steven_Z3R0
I'm at my wits end!
What is happening -
When I game in certain games (warzone) and programs I cant even start up themup - the system just goes right to BSOD: Watchdog_Clock_Timeout
This also happens when I use premiere, photoshop and aftereffects,
This happens when I try to stress test on the Intel Extreme Tuning Utility - BSOD Watchdog_Clock_Timeout
THos also happsn using the Intel Processor Diagnostic Tool - when it gets to the Prime Number portion of the test the system fails and BSOD Watchdog_Clock_Timeout
Though, when I stress test on 3d Benchmark it goes just fine.
This started happening with the game No Man Sky - Oddly enough this does not happen when I'm using VR (iracing)
Sys Specs:
i9 12900k - Not Over Clocked
64GB 4800 DDR5 (2 32gb sticks) - no XMP
RTX 3090 - NOT OVERCLOCKED
Samsung SSD 970 EVO Plus 2TB
Samsung SSD 980 1TB
I'm including my SSU Scan
What I've Tried:
I've ran a memtest and the memory is just fine - I have also tried to run the system with one stick and I've switch hem out 1 at a time and it still BSOD Watchdog_Clock_Timeout
I tried removing the GPU - and it still BSOD Watchdog_Clock_Timeout
Full windows install with not updates and it BSOD Watchdog_Clock_Timeout
I install the latest windows update and Latest Drivers - BSOD Watchdog_Clock_Timeout
I have Latest BIOS -BSOD Watchdog_Clock_Timeout
I reseated the CPU - the Ram - all the SSDs - BSOD Watchdog_Clock_Timeout
 What else can I try before  give up on this CPU?
Jean_Intel
Hello Steven_Z3R0,
We understand you have opened an email support case with us, and we will continue to help you through that channel now. We will therefore close this community case. Please, keep in mind that this thread will no longer be monitored by Intel.
Thanks for your understanding.
Best regards
Jean O.
