Processors
16150 Discussions
Help me!!!!
HoneyDew
Just installed a new i9-13900k inside of an Asus B760-A motherboard.
On the first load, the temperature seemed fine -- running at 35-40 degrees in bios.
Now that I'm using it and just updating drivers and post updating the bios, my CPU temperature hovers around 90 degrees celsius.
I don't know what to do. This is so lame.
RamyerM_Intel
Hello HoneyDew,
Thank you for posting in the communities. Considering the temperature readings you've provided, they remain within the acceptable operational range specified for this CPU model. However, I understand that you want to check for overheating issues. To do that, I have some questions about your system. Just to confirm, what is the model of the cooling solution that you used with this CPU? Additionally, please share the software that you use in monitoring the temperature. Does your system also randomly reboots? The reason I ask is because this is a common sign of overheating. I will be waiting for your reply.
Ramyer M.
RamyerM_Intel
Hello HoneyDew,
I am just looking for an update regarding the information we requested. Kindly please let me know about this information so we can further help you. I will be waiting for your reply.
Ramyer M.
RamyerM_Intel
Hello HoneyDew,
I hope you are doing well. As we have not heard a response in the past few days, we will proceed in closing this thread. Should you need assistance in the future, please submit a new question as this thread will no longer be monitored.
Ramyer M.
