When i want to run the game, there is an error called 8016 and is sas:
Intel has resolved an issue related to games failing to launch with game error code 8016 on systems with "Skylake" CPUs:
- 6th Gen Intel® Core™ Processors
- Intel® Xeon® Processors E3-1200 v5
- Intel® Xeon® Processors1500M v5
Please contact your system provider or motherboard manufacturer to ensure that you have the proper BIOS update installed.
For further support please contact Intel at http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport.
_------------------------------------------------------------------------------------------------------------------------------------
I can give more details here:
http://www.securom.com/message.asp?m=module&c=8016+&l=en SecuROM
When i start run the game:
(translate)
______________________________________________
Grand theft Auto IV X |
A required security module can not be activated. |
This program can not be started (8016). |
For more detailed information, please refer to |
(the Link) |
______________________________________________|
Comes this up.
When i click on the Link:
I hope someone can help me.Link Copied
The message indicates you need to contact your computer manufacturer or motherboard maker to obtain the latest BIOS update.
Have you tried contacting the board maker?
I will need some information about your system configuration. Please run the following utility and attach the results.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility
In order to attach files, make sure you select the "Advanced Editor" option in the top right of your reply window. You will then be presented with an attach file dialogue at the bottom of the reply.
Allan.
If you have a moment to get the system report, I would appreciate it. This will let us know about your system configuration.
Allan.
