Processors
14511 Discussions
Hi. I have updated my Asus Z170i Pro Gaming to the latest BIOS and inserted a I7 7700K. When I try to Boot with RAM in slot DIMM_B1 it get stuck shifting between DRAM LED and CPU LED. With RAM only in DIMM_A1 it boots normally.
AMehr7
With my I5 6600K it boots fine with RAM in both Slots. No bent pins.
Any idea whats wrong?
AlHill
Try different memory.
Try updating your bios.
Doc
AMehr7
n_scott_pearson
You installed the BIOS with this i5 installed, right? It should not be the i7.
AMehr7
Yes. Did the update with the I5 6600k prosessor and flashed the bios two times like Asus ​describes.
n_scott_pearson
Specifically, what memory do you have installed? Provide part numbers please, not description!!
AMehr7
Sure, using my I5 6600K for the moment.
DIMM_A1: KHX2666C15D4/8G
DIMM_A2: KHX2666C15D4/8G
n_scott_pearson
Not seeing anything out of the ordinary regarding this memory. I wonder if this processor you have has a bad memory controller. Was it new?
