Hi everyone,
I recently built a new system with the following specs:
• Intel Core i3-12100F with stock cooler
• AMD Radeon RX 5700XT
• Biostar H610M HP motherboard
600-watt power supply
The problem is that my CPU usage is at 100% during games, and my GPU usage is around 80%.
• Windows is up to date.
• BIOS is up to date.
• CPU drivers are installed and updated.
• GPU drivers are updated.
This is typically caused by the GPU drivers and/or other software, so not an Intel CPU issue. Try searching YouTube for topics such as 'How to Fix High CPU Usage AMD Radeon" - that will probably supply an answer.
