Processors
16296 Discussions
High temps benchmarking i9 12900k
Dankninja
So I just got a new setup i9 12900k new mobo msi z690 pro and a corsair h150 water cooling and honestly AMAZING god tier but I have an issue benchmarking and I'm not sure how I want to go about it. So pretty much all my temps reach high 80c too low 90c besides core 7 that reaches 100c in cinebench after 2 passes the weird thing is gaming I have no issues I usually don't go past 70c. But when I initially launch a game it'll reach up to 82c then shoot back down to 60-70c the entire time I game are these normal temps?
Dankninja
P.s on hwmonitor it say pcores 0-7 and e cores 0-7 the one that reaches 100c is pcore #7 and it gets 100 really quick I haven't ran a full 10 minute test becuase I didn't know if that could damage anything
Jean_Intel
Hello Dankninja,
Based on the processor specifications, the T-junction of the Intel Core i9 12900k processor is 100°C. Any temperature results below or equal to that value are considered normal and expected for this unit.
About this scenario, it is important to mention that, when using third-party tools, the results shown in those applications might not be that accurate.
To make sure if actually, the cores are working properly, even though the processor is not listed as supported, install and run the Intel Extreme Tuning Utility. You might be able to strictly monitor the temperature and the clock speed in real-time and confirm if there is something wrong with the unit.
It is also important to mention that when you benchmark the component, it will be submitted into artificial stress that will make the CPU run at its Maximum. This type of stress test does not reflect the same impact as a game will present, and the workload will be higher on the stress test, that's why you may see differences in the temperatures between gaming and benchmarking.
Jean O.
Jean_Intel
Hello Dankninja,
I hope you are doing fine.
Jean O.
Dankninja
Hello!! I'm sorry I've been busy I'm totally gonna check out what you said thank you for this information super helpful! I'm gonna download that program tonight and see what's up (:
Jean_Intel
Hello Dankninja,
Thanks for your response.
Once you try checking the XTU, let me know if you face any issues.
Jean O.
Jean_Intel
Hello Dankninja,
Jean O.
Dankninja
Everything worked great benchmarking with the utility you told me to download I didn't even go past 70c so everything seems great!
Jean_Intel
Hello Dankninja,
I am glad to know the information helped, and everything looks to be working fine. Hopefully, it will help other community members. Since the thread is now solved, I will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jean O.
